Old 03-01-2009, 04:28 PM   #53 (permalink)
NachtRitter
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Legacy Wagon 2.5 GT
Last 3: 23.78 mpg (US)
Maus - '94 Civic VX
90 day: 54.33 mpg (US)
Helga - '00 Jetta TDI
90 day: 52.94 mpg (US)
Thanks Clev, I'll check into that. It's not high idle *all* the time, but it kinda bounces while I'm coasting with engine on (I typically do that at night time or when the weather's bad) between ~900 and 1200 rpm (occasionally as high as 1500), and is a bit higher than normal when I'm stopped (~1100 rpm). Sometimes, if I'm stopped long enough, the idle gradually works its way down to ~900.
What throws me though is only one of the 3 ECUs I have seems to have a problem with the idle. The original Cali ECU works fine (even with my conversion harness installed) and the new Fed ECU I found this past weekend also works fine (though I haven't put more than 40 miles on the car with the new Fed ECU). Only the first Fed ECU (which I put in a few weekends ago) behaves differently. The model numbers on the two Fed ECUs are the same, so it is a mystery to me right now.
