Manual valve body automatic transmission
I'm not sure if anyone has ever discussed this here, but I wondered if anyone had experience with MVB's in street cars...
Personally, I can see both a performance and a MPG gain from it, b/c you can shift whenever you feel like it... (short shifting). Couple that with a low-stall convertor, and suddenly, you're slowly eeking away some of those efficiency losses that auto's suffer.
So if it turns out that this could be a beneficial mod, I'll get right on buying a core trans to work with, since there are several other things to do with the transmission that I'll be working with (Chrysler 31TE - 3-Speed, Lockup, no TCM) and I'll outline them all here with pictures and such so that anyone looking to do the same thing will have a simple resource to look back on for help.
