Nissan drive by wire throttle
Does anyone know how the drive by wire throttle works on a Nissan Versa? Is it a voltage based throttle? Does the gas pedal act as a potentiometer?
Could I use a switch to bypass the pedal and use a potentiometer to give a constant throttle setting?
