Old 03-04-2009, 11:31 AM   #5 (permalink)
Southcross
Manic Rabbit
Southcross's Avatar
Slow-n-Low - '81 Rabbit S
90 day: 33.97 mpg (US)
Originally Posted by shovel View Post
that's for the ECU to determine.
actually.. older cars with low compression engines don't have knock sensors so no, the ECU if it has one, won't do squat to the timing. I know I can retard the timing to help prevent ping, but that kind of counteracts the reason for increasing the compression.
I can actually get some pretty significant increases in compression... the head gasket I'm having made will increase the engine compression over .7 pts (from 8.2 to 8.9:1). I could theoretically go as high as 9.1:1, but I fear excessive mechanical interference if I were to do so.
