Old 03-04-2009, 02:42 PM   #5 (permalink)
ncs
RockMagnet - '04 Impreza wagon WRX
90 day: 26.16 mpg (US)
I used the five bolt holes used by the factory plastic undertray. Asside from the weight, it's just as easy to remove as the stock piece. I have found a problem though. If I drop something in the engine bay, it no longer falls out the bottom.
Coasting distance increased enough to screw up my stop light timing. Also, cruising load dropped a whole .01MPa.
