How is this different from a newer manual shifting auto? Example Audi Tiptronic. Select a gear, mash the throttle, it doesn't change gears till redline, or till you drop rpm below idle to downshift. Basically does what you're doing right? Full control to use each gear as you see fit, without needing a manual clutch.
