Old 03-05-2009, 03:16 PM   #3 (permalink)
Ryland
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
You might be turning the key back one click to far, if that is the case your steering might also be locking, this is bad, you should only turn the key back to the first click then forward a single click so your speedometer comes back on.
the check engine light might be coming on just because your computer is sensing that your engine is not running, if it goes off again then you have nothing to worry about, it is normal for your battery light and oil light to come on because your engine is not running so your alternator and oil pump are not turning.
