Old 03-06-2009, 01:14 AM   #7 (permalink)
Coyote X
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
an oddball idea I had but never did anything with was make a spacer that fit on the outside of the wheel with the lug nuts holding it in place. On the spacer put a sprocket of whatever size you wanted. In front of the tire drill a hole in the body and stick the motor shaft out the side of the car. There you go, an easy way to drive a back tire that will only look strange if you don't build a cover for it.
Lots of advantages to a setup like that. Easy maintenance and doesn't take much room up. Just a bit of the back seat at most. Still easy to maintain and repair the car. And if something breaks the worst needed is to use the lug wrench and take the sprocket and spacer off the rim. You would not even have to jack the car up to do it.
I figure since oddball ideas are being tossed out I might as well toss some of mine out there. Maybe someone might want to use it
My Convertible Metro XFI Plug in Hybrid Project build log
