Old 03-06-2009, 04:22 AM   #864 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Originally Posted by rmccomiskie View Post
Question: What signal voltage level is needed to trigger the external interrupt pins? The normal ECU signal is negative going. Looking back at my scope images of the flatline, I see that there are some verrry small positive blips. Could it be that they are triggering the external interrupts opposite of what is expected?
The pins will signal an "on" @~2.5 volts on a rising signal, and "off" @~2.2 volt falling signal.
So is it just instant that is off? Can it predict gallons needed for a tank refill pretty well?
