here's a couple of thoughts
frisbees
plastic plant pot trays
paint bucket lids
or find or make a suitable shape and vacuum form it... vacuum forming is what's used to produce these plastic blister packages. but the technique is also used is scale modeling to make things like aircraft canopees etc. so you might look for information in these circles
you could make a transparent cover for your bling bling rims, use non transparent plastic sheet, or use transparent sheet and paint it from the back! very smooth and durable finish that way
