Old 03-07-2009, 07:11 AM   #6 (permalink)
tasdrouille
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Originally Posted by metalshark View Post
with every car I know a warmer intake air temp actually chokes the engine, causes misfires, over heating, decreased efficiency, and many other bad things. (usually referred to as heat soak)
All the conditions you stated happen under high loads.
so why do you guys close off all heat dissipation holes, and use warm intakes?
Because most of the driving is done at light loads.
in high performance engines heat dissipation is usually used for better efficiency, and it was noted that fire burns more efficiently with cooler surrounding air.
Performance, not efficiency.
warmer engine bay and hot intake air sounds bad and puzzles me.
Im pretty sure heat soak negatively affects MPG
It depends on your driving behavior, and also your engine specifics.
Best case scenario you'd have a vacuum actuated flap connected to the intake manifold so when you jump on it you get cold air in, but warm air when cruising.
www.HyperKilometreur.com - Quand chaque goutte compte...
