Excessive electric usage indicated! Help!
Help!
I'm single and conserve energy, yet my usage is 2,300 kilo for 28 days in a small one bedroom, surrounded by other apartments and having only one wall exposed to outside elements. I live in an apartment that was built in 2006. My highest usage in a similar apartment was 600 kilo in the middle of winter. I have been tracking usage daily and I use 80-90 kilo compared to the 12-16 kilo that is the daily average in 15 other apartments in my apartment complex. I use this amount without heat or air conditioning on. The electric company tested the meter and found it to be working fine. I had a renters advocate test all the appliances for usage. They found no problem. We suspected the water heater, because I turned the water heater "breaker off" and the usage went down to 12 kilo per 18 hours with the heat set for 66 degrees. (It was very cold so other apartments used 19.8 kilo in these 18 hours). My landlord replaced the water heater thinking this could be the problem. No change. When I turned the main breaker off for the whole apartment for five hours, the meter did indeed stop, so its the correct meter. I tried using nothing in my apartment (no lights,etc) except for leaving the refridgerator and water heater on and I still used 67 kilo in a day. What do you recommend?
