Old 03-08-2009, 05:17 PM   #1 (permalink)
randerson0248
Mpguino does not time-out or reset.
I installed my "official mpguino preassembled" yesterday. I put it in the Radio Shack box that others have done.
It's in a 95 Del Sol S.
I assume, per instructions, that the display should shut off after 7 minutes of no injector or VSS pulses. Then when it restarts, it starts with a new current trip mpg. Is this correct?
Mine does not turn off or reset. Even after setting overnight, the display was still on, and the current trip data did not reset.
Is it possible that I have a wrong variable for timeout(micro sec)? What should that number be?
It seems to be working as it should except for the timeout/reset.
