Old 03-09-2009, 05:18 PM   #9 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Hi,
The squaring of the voltage comes from a combination of Ohms law and the definition of power:
I = amps
V = volts
R = resistance
I = V / R (Ohms law)
P = V * I (Power)
If you only have volts and resistance, combine the Ohms law with power:
P = V * ( V / R)
= (V * V) / R
What this means is for the same resistance, the power increases as the square of the voltage. So if the resistance stays the same, doubling the voltage results in four times the power. Cutting the voltage in half gives only 25% of the original power.
Now there is another approach that solves your voltage problem quite nicely, a step up/down transformer. I see any number of 1kw to 1.5kw 110/220 step up / step down transformers on Ebay in the $40-70 range. This would be an 'off the shelf' solution.
Bob Wilson
Local record
