Send a formal letter of complaint to your landlord via Certified, Return Receipt Requested USPS Mail and keep a copy of the letter for your records. The letter should outline the tests you've already done. The copy of the letter and the return receipt will serve as proof of when the landlord knew about the problem if/when you end-up in small claims court.
Try calling your utility company. Ask for their ombudsman. Explain the situation and how you've tested. Be sure to mention you think someone is hijacking your electricity after it goes through the meter! Get contact names and if possible a case number or something similar. (Again in case you end up in small claims court.) Hopefully the power company will come out and resolve the situation for you with out charge.
Good luck.
