Old 03-10-2009, 08:35 AM   #79 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
This weekend I made a small update to the project. I put together my RBBB (really bare bones board) arduino kit. This will be what will eventually be used in the car after all the tweaking is done.
dustybarn, I don't see why an ambient temperature sensor would have any bearing on the actuation of the grill block. The only thing I care about is not getting the coolant too hot so the fan doesn't turn on. Yes, ambient temp is going to affect that, but I don't actually care about ambient temp, just the coolant temp. I still want the car to warm up as fast as humanly possibly even if its 120 degrees F outside. Only after it is up to temp should the door open up.
