Thread: Spring F-EV-er
Old 03-11-2009, 09:59 AM   #3 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Hi Trev-
I temporarily forgot how cold Winnipeg can be! You still have lots of snow!
Do you have a voltmeter yet?
You should start by taking readings on each of the batteries, and researching how best to recharge them depending on their type. It's not good to let batteries sit partially discharged. After topping them up, you might want to set up a load test to see how much capacity they have.
As for their capacity: compare to the ForkenSwift which nominally has 220 AH batteries x 48 volts = a 10.6 kWh pack
4 of those 100 AH batteries @ 48 v = 4.8 kWh
Keep in mind those are "nominal" values and assume the batteries have 100% capacity (they lose capacity as they are used up). Also, since they will be used to deliver current at closer to their 1 hour rating, they won't deliver their rated capacity (hello, Mr Peukert).
They may be OK for testing and for very local trips, and that's fine if it's all you need. You can get a rough estimate of range from a 4.8 kWh pack knowing the vehicle will probably consume roughly .350 kWh per mile.
Also, don't forget you can't use your pack's FULL capacity (essentially draining it to zero) because you'll have no performance near the end of the charge as voltage falls, and draining to the end is not battery friendly. A rule of thumb is to size the pack so you can get your desired range from 50% of its nominal capacity. Moderate (50%) discharges are best for battery longevity.
