Oh, and if you have an old 120 volt electric clock (analog or flippy numbers) or can get one for a couple bucks at the thrift store, I would try and plug that into the water heater circuit if possible, set it for noon before you leave, and see if it has moved away from noon when you get back (i.e. someone has turned the circuit back on).
