For the first time in forever I found some dimmable CFL's for a fixture I have in the living room. This bad boy uses 5 40W small socket round bulbs and boy do they generate heat.
Well just replaced them with 5 3w dimmable CFL's. The light is better (Whiter) and absolutely no heat from them. Also, all 5 combined draw less power than a single bulb of the old type.
Can't wait to report on March's use, notoriously high due to a swing in temperature around here ..
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
