Old 03-15-2009, 08:09 AM   #6 (permalink)
brucepick
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 47.09 mpg (US)
Good going! EOC has tremendous potential to raise your overall FE. It's especially helpful on a cold engine, as it runs a very rich mixture until it comes up to the required temperature.
You mentioned clutch starting - hopefully you've seen the recommendation somewhere, to clutch start in 5th gear, even if you'll be putting it into another gear once started. That spins the engine a bit slower, with less jolt to the entire drivetrain. It's enough to start the engine unless possibly you're going very slow, like under 20 mph.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
