Old 03-16-2009, 10:56 AM   #9 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 41.69 mpg (US)
I don't hear the fan at all, and have no way of knowing when it is on.
I can see the temps on the ScanGauge. Sometimes it rises and drops a bit.
What do you think are the max temps before I open up the vents a bit?
I am thinking below 220F max peak is OK, if it goes above that then more air is needed.
Nissan Versa Aeromods
