I'm pretty sure this has been asked before, but I couldn't find it, so here it is:
When you turn the car off, does the
MPGuino record mileage for the time between turning the key to off and then to run? I know it's only like a second, but a lot of them will add up to a bit of mileage, which might affect the calibration.
And also, does the car's odometer behave the same as the
MPGuino? So like, if the MPGuino can't record mileage for that second, does that also mean the odometer can't record the mileage either? I'm thinking that's the case, because they both work off the same source, but I just wanted to make sure.
