Right, that makes sense. The speedo works off a signal generated by the odometer though, right? And that same signal is what drives the
MPGuino, I think.
So, if it generates that signal during the transition between turning the key to 'off', and then to 'run', then it should be accurate. Otherwise, it would be a little bit off.
