Old 03-19-2009, 07:30 PM   #123 (permalink)
consaka
Active Learning - '93 Suburban Silverado
90 day: 10.67 mpg (US)
Originally Posted by dcb View Post
You've seen das Durchflußgeber ?
0.396 gph to 39.6 gph for about $60
Problem is that it doesn't quite get low enough for many idlers. If you put that type in parallel then they will see below .396 and get inaccurate. Parallel drip counters might work (how many drips per second can one count reliably?)
re: 555: a $3 pic can replace a whole army of them.
So is there some physics invloved to limit max drips per second before they change volume or otherwise are better described as a stream?
aye .. I think you might have missunderstood me.. I agree this one is too expensive and doesnt register low enough. to start stacking them you need to start out with something that may already be too low of a flow for the bigger engines. Then you parallel them for the bigger engines.
