Old 03-20-2009, 12:22 PM   #33 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Originally Posted by Fabio View Post
And you could be right about the relative difficulty of beating the car's original mileage.
You may want to plug the Insight's specs into this tool: Aerodynamic & rolling resistance, power & MPG calculator - EcoModder.com
It'll give you an indication of, for example, the impact of weight on power required at different speeds (you can change variables and re-calculate as much as you like). I think you'll find that you might be overestimating the savings to be gained in highway driving through weight reduction.
Run the numbers of sticking a small diesel (eg. from the 1st gen smart fortwo) into the Insight. That, I think, is your only route to beating the car's "stock" highway fuel economy (and I may be wrong there - I don't know how close Honda gets to diesel efficiency with the lean burn 1 L engine).
EDIT: Of course, then you'll have a 40 hp Insight that takes ~20 seconds to get to 60 mph, flat out. But you're used to driving an XFi, so maybe that doesn't matter! (Not being facetious: 20 seconds to 60 mph is acceptable in my books.)
