Old 03-21-2009, 03:08 PM   #465 (permalink)
Intrigued
Losing the MISinformation
Intrigued's Avatar
Quad Cam - '00 Intrigue GX
Last 3: 25.94 mpg (US)
Hey, don't feel stupid yet! The questions remain as to whether the built-in crimper 1) actually has anything anywhere close to what you need, and 2) has good enough metal to actually make more than 2 (okay... 3 on a good day) crimps to begin with!
(I have a pair of bolt cutters that already looks like what you did to yours, but it got that way from trying to cut open a lock. Not one of those case-hardened ones, either... After that I found out you could soften the metal you want to cut by using a propane torch running on MAPP gas...)
ANYway.... if it actually does work, you can now do two crimps at once!
The brake pedal is my enemy. The brake pedal is my enemy. The brake pedal...
