Old 03-23-2009, 08:29 AM   #3 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Welcome to EM. It sounds to me as though you have a bad O2 sensor. From the wiki:
Mono-Jetronic always had adaptive closed-loop lambda control, and due to the simple engine load sensing, it is heavily dependent on the lambda sensor for correct functioning.
I definitely consider testing and/or replacing it.
Good luck with the new car and let us know how it goes!
