Old 02-12-2008, 12:52 PM   #16 (permalink)
diesel_john
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
good discussion modders. i just found out i have to grind the cam lobes off a bit because they hit even with the buckets out. the valves have worn down into the seat. i am thinking cut the rods off and take out the clearance, so they clamp on and can't turn. not much room between the rod and block. next i need decommisson two ports on the injector pump. that should be interesting. all rod throws are individually counter weighted on this crank.
How many votes for even fire, uneven balance?
How many votes for even balance, uneven fire?
1.6 D short block
1.6 D head
third pic is for comic relief.
