Originally Posted by TomO
I'm getting much inspiration for my MPGuino build. I actually have a project box sitting around that should be the right size to do the same thing as you, rmccomiskie. In fact, now I have an idea of what kind of room I have to add the LED output for my OEM wideband display in the same box.
There's a little room on the right side. If you're using the later
MPGuino ver. 2 from Fundamental, both the RJ11 and the USB connectors are on the left end of the board. There should be nothing in the way on the right.
