If it's suggestion season, let me add one, needed to sift through the walrus-beach that is the ecomodder garage....
Could there be a field that specifies bikes, biodiesels, EVs and other odd-balls (I respect them all, just not relevant to my searches) so that I can separate them out and check vehicles that fall in my bracket , to zero on mods and techniques to learn from and adopt.
I also impose a 'figure of merit, composed of a combination of parameters of my choice (usually absolute MPG * % over EPA) but it may be too radical to impose constraint like this
That's how I figured out my Guru in the form of PaleMelanesian...
Maybe tranny type (AT/MT) can also be included as a parameter.
All these parameters can be gathered in the same page as that used for gathering the vehicle info now, just by modifying it for these fields.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
