When you say programmable systems, do you mean LED's flashing in unison or a flash of light that runs up and down a row of LED's? That kind of thing?
I personally would not spend too much time on learning C, because if you go through the tutorials and write a few simple scripts based on the tutorials, you will learn how to write the code. End with a ; , make sure you declare your variables. Go to the reference book or the arduino forum when things are not working.
I can tell you this: with some effort, you will be able to create and control electronic devices that you never thought you would be able to.
