Old 03-27-2009, 04:03 PM   #6 (permalink)
vtec-e
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
Originally Posted by hummingbird View Post
It is due to this reason that some early fast fighter aircraft fuselages had a strange 'dimple' at the point where wings met the fuselage The wings added a sudden additional area when cross section is considered. That prevented the aircrafts to overcome drag particularly flying close to Mach1 figure. the trick designers used there was to give a 'dimple' in the fuselage, that reduced sudden increase in the cross-section area. This helped push aircrafts to higher speeds. google and you can find some references in the US air force fighter aircraft history.
Whoaaaa!!! There's a random nugget of knowlege! Thanks!
ollie
