Old 03-27-2009, 08:08 PM   #8 (permalink)
hamsterpower
one of thOOOse people
twitchy - '98 civic dx + sir + ls
90 day: 33.35 mpg (US)
greywater ideas
Hi Ben,
Looks good so far but if I may, Please don't add a tee behind the toilet for clean water. instead add clean water to the tank at the other end of the system as needed. You CAN NOT have any chance of grey water getting in to the clean water supply.
Secondly for your filter you can use a fine filter inline like you had before but add a course filter, maybe sand or gauze, between the washer and the tank. A small container with a hole in the bottom covered by a few layers of fish filter cotton, followed by course sand on top of the tank would be ideal. Run the washer drain line in to this container. This way the tank stays somewhat clean too. In fact... if this was in the top of the tank.. like a rain water collection system you could run the overflow out of this container to your drain. By letting this overflow from time to time it might self clean this filter by back flushing to the drain.
There's my first post. I hope I made sense.
