Old 03-28-2009, 09:53 PM   #1045 (permalink)
brihoo2k
learning to be ecominded
brihoo2k's Avatar
Ive got spring compressors if you need different ones but heres a trick that I've done in the past. Get yourself a set of ratchet straps and use them in place of the spring compressors. I'd be willing to bet my spring compressors are the same as your and would put you in the same situation. Your going to need something to compress them bigger ranger springs
Does the voice in my head bother you?
