Old 02-13-2008, 12:32 PM   #1 (permalink)
Daox
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Another Autospeed aero article: methods for measuring aero drag
http://autospeed.com/cms/A_109741/article.html
They describe a different method for measuring aero drag. Not bad, but I wonder how accurate it is. Its hard to say if a MAF sensor's voltage is directly proportional to engine load. For example, say you get 1 volt @ 60 mph and you are using 10 hp to maintain that speed. Does .5 volts mean you are now using 5 hp to maintain speed? I wouldn't be too sure. But, it is a way to measure improvements.
