Originally Posted by windchoco
Thanks a lot...
My tire sidewall (Yoko S-Drive), says do not pump more than 270kPa, but yet when I see the posts here, it seems that >50 psi is common ??? Will it explode or something?
Sorry for the noob questions..
Well, here's what I do. And consider, before I got the Civic I was a driver of an old Volvo, which is all about safety. My point being, I'm not a person to take huge risks.
I run my tires about 10% over the sidewall rating. That is, mine now are rated 44 psi and I run them at 50 psi. I measure them when cold in the morning, before driving. They go up about 4 psi from driving and also go up about 1 psi per 10 degrees F. as the day gets warmer. Sorry, I'm no good at translating to kPa but I think you get the idea.
Some cars get very tough to steer without power steering. However I did find that increased tire pressure makes the steering lighter.
Make sure you use a good gauge when running high pressures. A cheap one might not be truthful.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on
The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
