Yes, it has a correction adjustment for speed/distance. It's on pg. 17 of the manual. Follow Menu > More > Setup > Speed.
You can increase/decrease the speed/distance in 1 % increments.
I haven't had a need to adjust this correction (I don't do rallys).
Apparently it reads out current speed while you adjust the correction so if you have a GPS running along side, you can get it dead on, within the 1% increment limit.
Otherwise, my understanding is you need to determine the correction you want to apply, then enter it as + or - the % needed. That is, if you're stopped, the speed shown is zero but you can still enter a correction %.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
