Thanks... I guess i will try to increase the pressure gradually after every 2 trips to the gas station or so... to build up some confidence... Hopefully it will not cause the tires to wear unevenly (which will result in rotation and alignment costs)
Is there anyway to make the power steering continue to work even when I EOC ? For example like the audio and air-cons, which would still work even when engine is off...
