Old 04-03-2009, 03:01 PM   #1072 (permalink)
Joe_Bloe
Bucket - '94 Escort Wagon
90 day: 36.46 mpg (US)
Originally Posted by bennelson View Post
I tried to cut it as close as I could, but the right side ended up being about half an inch taller than the left. Maybe I will need to go back in there and grind down a bit more.
What about just swapping the springs so the higher spring is on the driver's side? With the heavier load on the left (assuming you aren't running turbo-boost batteries in the shotgun footwell) that might be all you need?
