Alot of electric tank less water heaters require 60-80 amps at 220 volts, my boss installed one a few months back, an electrition friend warned us ahead of time that this was a bad idea, the reason for this is that when you turn the hot water tap on the lights in the house dim, this causes some lights to have shorter lives and causes some other problems with things like the stereo.
