1 qt every 300 miles sounds like a bad seal somewhere, more than it sounds like bad rings. Rear mains, oil pump seals, and headgasket's can cause that kind of loss but if you are burning it all than you probably have more than just ring damage, the walls of that cylinder are probably scored pretty seriously, or way out of round.
any oil under the car?
