Old 04-06-2009, 01:29 PM   #771 (permalink)
MPaulHolmes
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
The thermistor is pushed into a hole that's drilled into the heat spreader, so there would have to be leads that get connected to the control section. I think those Molex connectors, that plug into pins that get soldered to the PCB, like the ribbon cable inside the computer would work really well. I don't know a good way to coat the bus bars. Can it be spray painted? Or does it have to be electrolysis?
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
