Sure I would be interested in the dissimilar metals chart. Did you download it from the net. If so maybe just a link to the site would do. Or try zipping it?
As far as an electrolyte is concerned, I was under the impression that all you need is humidity in order to get things started down that path. I don't know how the heat conductive goo that is often used to assure the transfer of heat effects this reaction. Just things to keep in mind.
