Old 04-07-2009, 09:16 AM   #134 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
03 Prius - '03 Prius
90 day: 52.67 mpg (US)
10 Prius - '010 Prius III
90 day: 53.31 mpg (US)
Hi,
I was surprised to find one of my charts in this thread so if there are any questions. As background, I have a Graham miniscanner that reports up to six data metrics in just over 1 second. There are nearly 100 metrics that can be chosen but only six recorded via the RS-232 line.
For these charts, I measured MG1 torque, which is 28% of the ICE torque. Combined with ICE rpm, I have the shaft power into the transaxle. For fuel flow, I can use either mass airflow or injector timing.
Initial Engine Efficiency Chart:
I prefer this chart because the small red bubbles do a better job of showing the peak efficiency region. It also includes the HP graph.
This is another look at similar data from a single fuel tank:
This is graph from one of the SAE papers on the Prius I was trying to replicate:
Data from another trip:
Now one of the Prius SAE papers on the Prius has this operational line:
So I made a variation of that chart:
This chart is a little easier to deal with because it uses engine RPM as the X-axis and the expected torque. Understand this is more of a model chart versus the earlier measured charts.
Bob Wilson
* - SAE 2004-01-0064 - "Development of New-Generation Hybrid
System THS II - Drastic Improvement of Power Performance and Fuel Economy", Koichiro Muta, Makoto Yamazaki and Junji Tokieda
Toyota Motor Corp. Reprinted From: Advanced Hybrid Vehicle Powertrains 2004 (SP-1833) 2004 SAE World Congress Detroit, Michigan March 8-11, 2004
Local record
