Old 02-14-2008, 04:26 AM   #9 (permalink)
DAN
can you see if it closes all the way. if it new it sure should. i think the working water temp. is about 170. can you warm it up and use a thermometer on the water. even a new one can be bad. if nothing ealse works can you pull it and heat water in a can and check thep. and see if its working. i can't see the gar maker blow it that bad.
