Originally Posted by Drive Stick
I have recently been using the bump start instead of key start in my 5 speed after coasting, because the starter makes a terrible "oh sh*t i cant keep up with the flywheel" sound when the key is first switched to start posotion while coasting.
Not sure what technique you are using. The engine, and therefore the flywheel, would not be turning if the clutch were depressed and the ignition off.
The subject is replete with opinions, mine included, and very little data. If I had a MT, I would do some EOC, in neutral of course, on those stretches which were worthwhile. Personally, I do see lots of stress and extra cycles on transmissions and clutches resulting from the practice, so IMO it is a bit of a tradeoff. Lots of folks seem to get away with it, for the period that they own the car. Those who inflict damage may not be 'fessing up
