Old 04-09-2009, 03:49 AM   #9 (permalink)
consaka
Active Learning - '93 Suburban Silverado
90 day: 10.67 mpg (US)
Originally Posted by rmccomiskie View Post
Exactly! Don't get wrapped up in the name, i.e. uS/gal. Think of this as some arbitrary unit of time that your injector must stay open on average to spray one gallon of gasoline.
As dcb says, you need to identify the type of injector. In its basic form, the MPGuino is not designed to handle peak and hold injectors. If yours is that type, you've got some work ahead of you in both hardware and software.
they have the little orange colored rings on the terminal. I hooked my digital ohm meter to it and set it for 200 ohms. The reading I got was 1.7
So Im a little rusty on these digital meters.. is that 1.7 ohms? or 1.7*200?
