jazzie604 -
Hmmm, I didn't think of that. It would essentially be a 3-point connection. 1 Spring(s) connection and 2 hinge connections. I can drill a hole in the bottom center of the license plate, or build a whole top mount that takes the flexing license plate out of the equation. I used two springs because the bottom corners of the license plate is where the ready-made holes were.
CarloSW2
