you can run them on SVO with very little work, saving you from burning gasoline at all. (straight vegetable oil.)
The SVO is a consideration too. This was the original reason I bought the SDL. but decided to keep it original. I will surely look into SVO if the 190d is selected keeping in mind that there are some cars better suited for SVO. A good friend has been running his F250 for 1yr now on SVO.
