Old 04-11-2009, 07:43 PM   #28 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
The resistors are all built in, just need to tap your wiring. If your 94 is like this 98 then you will have a yellow/green at the ECU behind the glovebox and a yellow/blue at the injector under the air cleaner (for the injector connection), use constant 12v for power.
Maybe this helps:
Metro - EcoModder
